Advanced control using temperature
Hi is it possible through Kincony software to do such logic:
I would like to control two outputs the first output is to increase the flow of water the second to decrease the example:
temperature sensor measures the temperature of water that flows through e.g. a heater at a setting of, for example, 30 degrees it does nothing after exceeding e.g. by 3 degrees the logic turns on output ''1'' for 10 s (to increase the flow and at the same time reduce the temperature of heated water) the thermometer measurement would have to measurement of the thermometer would have to be taken at intervals, e.g. every 20 seconds (adjustable) and the principle of operation is reversed if the temperature drops after some time logic turns on output ''1'' to reduce the flow in order to equalize the temperature and so on and so forth the measurement would have to be taken at intervals due to the reaction time of cooling water.
Is it possible to set it up this way through the IFTTT website
It must work on the principle of a temperature controller only with a delay ( warm up or cool down response time)
i suggest you write your own arduino code for your requirements.
2 Guest(s)
