A16: IFTTT Time based actions not working
Hello.
I set up an A16 device with the software version v.2.2.12. The display of the time on index page is still not correct. It should always follow the format YYYY-MM-DD HH:MI:SS.
Unfortunatlely the date & time is displayed like this: "2025-02.27 7:5:27" Please see attached image.
In addition to that, the IFTTT time function is not working. When time is reached, the configured output is not switched on.
What am I doing wrong?
can you change to UTC+8 for a test , whether timer work well.
(7 hours ago)admin Wrote: can you change to UTC+8 for a test , whether timer work well.
Hello.
Thank you for the reply. I did this several times on 3 different A16s. It did not work on any device. :-(
take a photo of your board, how you wire cable.
(2 hours ago)admin Wrote: take a photo of your board, how you wire cable.
Please find picture in the attachment.
When I manually swich on channel 15 (Monitor page) it works fine.
