03-09-2025, 07:58 PM
Good afternoon, I would like to know if you can help me with a project to be carried out. I needed a hybrid system, that is, control lights, blinds, gate motors via Home Assistant and at the same time manually in case the server is damaged. The server I want to use is KC868-Server16.
I needed to know if I have to add the KC868-A16V3 module and subsequently relays.
Thank you very much
Thank you very much
