Use case - possible?
Can I use the product for this use case:
- recieve RS232 signals from external source for open/close of the relay
- attach OLED screen and configure display myself
- read signal from distance sensor (ultrasonic analog / laser digital)
- read temperature to adjust ultrasonic measurement (hot/cold air)
- send measurements to server via HTTPS over LAN
do you write your own arduino source code?
yes I do
which kincony product model you want to use?
Need 6-8 relays and was looking at kc868-a8 (need lan)
if you want KC868-A8, you can wait for some weeks, we will release new version KC868-A8v3 model, that will include SSD1306 LCD and more free GPIOs for user.
Sure, I Can wait. Sounds good.
I am interested in using these for a new product. How many years do you plan this or a newer version to be available?
Potentially I could buy hundreds if the project works.
under developing...
