03-16-2025, 06:12 PM
I am building a new house and will like to create a smart system for all the lights and wall plugs in the house that includes many ESP32 sensors (humidity, temperature, magnetic, movement etc...) that could be used by home assistant in automation.
Also I am in a budget since there are many expanses with the new house and I will like to see if I can use the following setup:
1. Two KC868-A16v3 ESP32-S3 16 channel GPIO module that comunicate between eachother.
2. Each board will be used to controll a KC868-E16v2 relay board or a contactor. (Not sure which one will be the better option)
3. One board will be use for lights and the other board will be used for wall power outlets.
4 Also LEDs will be used in the house that need to be able to dim if needed.
5. I would like for the light switches to work also without HA but also to have a backup plan to make them work. (Ex to connect them also teleruptor so that it will work even if the A16 or A32 boards will be turned off or burned.)
6. Could perhaps A32 board be a better option for controlling the lights?
Can you please confirm if the board mentioned above are the correct ones or maybe could you please suggest a better architecture that I could use to design the the electrical grid of the house?
Really appreciate of help on this matter,
Erazer
Erazer
