A32PRO - multiple 1-wire
I use A32PRO with software version v3.4.0 only via KCS web page and then to Loxone. I also bought several DS18B20 sensors with A32PRO, but only later I found out that I can only connect 1+1 piece to W1 and W2. I found a few posts here that solve this via ESP HOME, but I never used them.. How to get support for multiple sensors at once into an already running A32PRO without disrupting my existing settings? Or how can I make a backup of my program in A32PRO, in case something gets disrupted.
Sorry for the noob question, but I have never worked with ESP HOME and I am afraid that I will ruin the existing installation, on which part of my house is already running.
I found these threads here on the forum:
https://www.kincony.com/forum/showthread.php?tid=2290
https://www.kincony.com/forum/showthread...ht=DS18B20
https://www.kincony.com/forum/showthread...ight=1wire
Can I use one of them to get support for multiple DS18B20 sensors into the KCS firmware and subsequently into Loxone?
Thank you
A32Pro support many way for sensor. now KCS v3 use 1 GPIO for 1 DS18B20. But you can also connect with KinCony TS RS485 termperature sensor, that support one RS485 bus MAX 254pcs of sensors.
if you MUST want to use DS18B20, in future we will update KCS v3 firmware to support one GPIO with multi DS18B20 sensors.
