Disable checkbox for the IFTTT schedule's time setting
Could the next KCS 868 firmware revision include a disable/enable checkbox for the IFTTT schedule's time setting? This would greatly benefit applications that need to run continuously throughout the day, like temperature, pressure, or level control, with varying daily thresholds.
Hardware : KC868 A16
Software  : KCS 868 V2.2.12
if you don't want to use timer, just not ADD "timer". sorry, i don't understand your "disable/enable checkbox" significance?
(03-22-2025, 07:23 AM)admin Wrote: if you don't want to use timer, just not ADD "timer". sorry, i don't understand your "disable/enable checkbox" significance?
As previously stated, the requirement is to adjust the setpoint based on the day of the week. For example, a room temperature setpoint of 23°C for Monday, 24°C for Tuesday, and  25°C for Friday, with each setpoint being applied for the full day for continuous room temperature control (currently, it only works once per time setting), please advise on how to set up IFTTT rules for this application.
if use by this way, you can create some different IFTTT command for different timer.
(03-23-2025, 03:31 AM)admin Wrote: if use by this way, you can create some different IFTTT command for different timer.
Possible to do that for the full day?
