04-03-2025, 06:39 AM
* Description:
* This Arduino program reads the state of a 16-channel PCF8575 I/O expander
* each pin is represented as a bit in a 16-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
// Set I2C address
PCF8575 pcf8575_IN1(0x22); // The I2C address of the PCF8575
pcf8575_IN1.begin(); // Initialize the PCF8575
Serial.println("KinCony TA 12 channel input state 0:ON 1:OFF");
uint16_t state = 0;
for (int pin = 0; pin < 12; pin++) {
if (pcf8575_IN1.read(pin)) {
delay(500); // Delay 500ms
2-digital-input.zip (Size: 837 bytes / Downloads: 749)
2-digital-input.ino.merged.zip (Size: 192.29 KB / Downloads: 790)
