Have KC868-AP
I try integrate it to Home Assistant over MQTT, but it not working.
I have this template:
when I change dimmer value in HA, message received on device and dimmer value is changed, but light state in HA still Unknown.
I try to check status JSON in linter and it have mistake:
after "dac16":{"value":0}, has extra comma.
if I publish valid JSON in status topic without extra comma HA gets status of dimmer channel correct:
Board Model
KC868_AP
Software Version
v2.2.12
Build Date
Feb 28 2025 14:41:30
Serial Number
C82E18C85DFCI try integrate it to Home Assistant over MQTT, but it not working.
mqtt:
light:
- name: 'KC868-AP-1-DIMM-1'
unique_id: KC868-AP-1-DIMM-1
schema: template
command_topic: "KC868_AP/C82E18C85DFC/SET"
state_topic: "KC868_AP/C82E18C85DFC/STATE"
command_on_template: >
{% if brightness is defined %}
{"dac1":{"value":{{(brightness / 255 * 100) | int - 1}}}
{% else %}
{"dac1":{"value":255}}
{% endif %}
command_off_template: >
{"dac1":{"value":0}}
state_template: >
{% if value_json.dac1.value == 0 %}
off
{% else %}
on
{% endif %}
brightness_template: >
{{ (value_json.dac1.value / 99 * 255) | int }}I try to check status JSON in linter and it have mistake:
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"input17":{"value":false},"input18":{"value":false},"output1":{"value":false},"output2":{"value":true},"dac1":{"value":0},"dac2":{"value":0},"dac3":{"value":0},"dac4":{"value":0},"dac5":{"value":0},"dac6":{"value":0},"dac7":{"value":0},"dac8":{"value":0},"dac9":{"value":0},"dac10":{"value":0},"dac11":{"value":0},"dac12":{"value":0},"dac13":{"value":0},"dac14":{"value":0},"dac15":{"value":0},"dac16":{"value":0},}if I publish valid JSON in status topic without extra comma HA gets status of dimmer channel correct:
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"input17":{"value":false},"input18":{"value":false},"output1":{"value":false},"output2":{"value":true},"dac1":{"value":0},"dac2":{"value":0},"dac3":{"value":0},"dac4":{"value":0},"dac5":{"value":0},"dac6":{"value":0},"dac7":{"value":0},"dac8":{"value":0},"dac9":{"value":0},"dac10":{"value":0},"dac11":{"value":0},"dac12":{"value":0},"dac13":{"value":0},"dac14":{"value":0},"dac15":{"value":0},"dac16":{"value":0}}
