04-20-2025, 07:34 AM
* This program controls 64 outputs using 4 PCF8575 I/O expanders.
* It sequentially turns on outputs 1 to 64, then turns them off from 64 to 1, in a loop.
* I2C Pin Definitions:
* - SDA: GPIO 48
* - SCL: GPIO 47
* PCF8575 Addresses:
* - Output 1~16 : 0x25
* - Output 17~32: 0x24
* - Output 33~48: 0x21
* - Output 49~64: 0x20
* Delay Time:
* - 200 milliseconds between switching outputs
#include <Wire.h> // Include the Wire library for I2C communication
#include <PCF8575.h> // Include the PCF8575 library
#define SDA_PIN 48 // Define SDA pin
#define SCL_PIN 47 // Define SCL pin
#define DELAY_TIME 200 // Delay between operations in milliseconds
// Create PCF8575 objects for each chip
PCF8575 pcf_1(0x25); // output 1-16
PCF8575 pcf_2(0x24); // output 17-32
PCF8575 pcf_3(0x21); // output 33-48
PCF8575 pcf_4(0x20); // output 49-64
// Array of pointers to PCF8575 objects
PCF8575* pcfArray[4] = { &pcf_1, &pcf_2, &pcf_3, &pcf_4 };
Wire.begin(SDA_PIN, SCL_PIN); // Initialize I2C with specified pins
Serial.println("PCF8575 64-Channel Output Control Starting...");
// Initialize all PCF8575 modules and set all pins to HIGH (OFF)
for (int i = 0; i < 4; i++) {
pcfArray[i]->begin();
for (int j = 0; j < 16; j++) {
pcfArray[i]->write(j, HIGH); // Turn off all outputs initially
// Turn ON outputs from 1 to 64 (LOW)
for (int channel = 0; channel < 64; channel++) {
int chipIndex = channel / 16; // Which PCF8575 (0 to 3)
int pinIndex = channel % 16; // Which pin on that PCF8575 (0 to 15)
pcfArray[chipIndex]->write(pinIndex, LOW); // Turn ON the output
delay(DELAY_TIME);
// Turn OFF outputs from 64 to 1 (HIGH)
for (int channel = 63; channel >= 0; channel--) {
pcfArray[chipIndex]->write(pinIndex, HIGH); // Turn OFF the output
delay(DELAY_TIME);
1-output.zip (Size: 1.03 KB / Downloads: 676)
1-output.ino.merged.zip (Size: 192.12 KB / Downloads: 660)
