NodeRed Disconnected Randomly
Dear Support.
Is the away to ensure that NodeRed is running at all time?
Is there any changes i need to make on my laptop that will re-connect the NodeRed when it disconnect?
This is because once NodeRed stops the nodes are not able to update the IOS devices until the NodeRed is up and running again?
I have created a task schedule to automatically run NodeRed when the laptops starts but I notice once NodeRed disconnect it does not want to reconnect until i go into the schedule and re-run the task.
Will it be more stable if  I use Raspberry Pi?
Thank You
Regards
Subas
Strongly recommended use Raspberry Pi. it's more stable, Most server is running on Linux OS, not use Windows OS.
I have already install on Windows and Raspberry Pi (Linux). Pi is stable.
(10-27-2020, 02:02 PM)admin Wrote: Strongly recommended use Raspberry Pi. it's more stable, Most server is running on Linux OS, not use Windows OS.
Dear Sir.
Thank you very much for the answer.
Thank You
Regards
Subas
