10-04-2021, 11:59 AM
as per Request in Youtube Channel here a small Example List of IO´s needed per room excluding switches and Relais. This is just a Sensor list of Sensors that are typically used.
I hope you can see that Sensor inputs are always Welcome.
I have not added Analog Sensors that are usually mounted. If you need them i would add them too.
These are just some example rooms. Garage and Outside of house is missing too. Kids Bedrooms are the Same amount like normal Bedroom.
I hope this helps Kincony to understand why we need many Inputs.
example IO List.xlsx (Size: 10.68 KB / Downloads: 1,042)
