T128M ESPHome yaml for home assistant
  friendly_name: t128m
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 48
     scl: 47
     frequency: 400kHz
   - id: bus_b
     sda: 12
     scl: 11
     frequency: 400kHz
pcf8574:
  - id: 'pcf8574_hub_out_1'  # for output channel 1-16
    i2c_id: bus_a
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_out_5'  # for output channel 65-80
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_6'  # for output channel 81-96
    i2c_id: bus_a
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_out_7'  # for output channel 97-112
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_8'  # for output channel 113-128
    i2c_id: bus_a
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for input channel 1-16
    i2c_id: bus_b
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32
    i2c_id: bus_b
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48
    i2c_id: bus_b
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for input channel 49-64
    i2c_id: bus_b
    address: 0x22
    pcf8575: true
  - id: 'pcf8574_hub_in_5'  # for input channel 65-80
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_6'  # for input channel 81-96
    i2c_id: bus_b
    address: 0x24
    pcf8575: true
  - id: 'pcf8574_hub_in_7'  # for input channel 97-112
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_8'  # for input channel 113-128
    i2c_id: bus_b
    address: 0x20
    pcf8575: true
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_3
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_4
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_5
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_6
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_7
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_8
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      number: 8
      mode: OUTPUT
      number: 9
      mode: OUTPUT
      number: 10
      mode: OUTPUT
      number: 11
      mode: OUTPUT
      number: 12
      mode: OUTPUT
      number: 13
      mode: OUTPUT
      number: 14
      mode: OUTPUT
      number: 15
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_2
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_3
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_4
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_5
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_6
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_7
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
      pcf8574: pcf8574_hub_in_8
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      number: 8
      mode: INPUT
      number: 9
      mode: INPUT
      number: 10
      mode: INPUT
      number: 11
      mode: INPUT
      number: 12
      mode: INPUT
      number: 13
      mode: INPUT
      number: 14
      mode: INPUT
      number: 15
      mode: INPUT
## pull-up resistance on PCB
      number: 15
      number: 16
      inverted: false
      number: 17
      inverted:  false
      number: 18
      inverted:  false
## without pull-up resistance on PCB
      inverted:  false
      number: 8
      inverted:  false
      number: 9
      inverted:  false
      number: 10
      inverted:  false
  - platform: adc
    pin: 7
    name: "t128m A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "t128m A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
          } else {
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "t128m A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "t128m A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
download yaml file:
.txt   T128M-HA.txt (Size: 45.57 KB / Downloads: 450)
