06-23-2025, 05:36 AM
* RS485 Communication Test with Direction Control (SP3485EEN)
* The TXD pin is defined as GPIO 13, RXD is GPIO 21, and EN is GPIO 14.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 21 // RS485 Receive
#define RS485_TXD 13 // RS485 Transmit
#define RS485_EN 14 // RS485 Direction control (High: Send, Low: Receive)
// Create a hardware serial object on UART1
while (!Serial);
// Set RS485 direction control pin
pinMode(RS485_EN, OUTPUT);
digitalWrite(RS485_EN, LOW); // Start in receive mode
// Initialize RS485 serial communication
Serial.println("RS485 Test Start (with direction control)");
// Prepare the message to send
String message = "Hello from KinCony T128M!";
// Switch to transmit mode
digitalWrite(RS485_EN, HIGH);
delay(2); // Short delay to allow driver to switch
// Send the message
rs485Serial.println(message);
rs485Serial.flush(); // Wait for transmission to complete
// Switch back to receive mode
Serial.println("Message sent. Waiting for response...");
// Wait for a response (up to 1 second)
unsigned long startTime = millis();
while (millis() - startTime < 1000) {
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
break;
delay(2000);
3-RS485-Test.zip (Size: 1.02 KB / Downloads: 690)
3-RS485-Test.ino.merged.zip (Size: 186.66 KB / Downloads: 741)
