KC868-A16S Arduino Issue
I have purchased a KC868-A16S unit and am having difficulties getting it to work with Arduino codes. I downloaded the firmware to the device and was able to control it via the Wi-Fi connection, but no Arduino code will work with Relay Control. I tried the example codes that were provided in the Arduino library: they all seem to upload but none seem to actually work on the board. I even checked via RealTerm to see if the code was taking, but it said that the Arduino example code failed. Let me know if there is anything I can do to fix this, thank you.
this is relay output arduino source code for KC868-A16S: https://www.kincony.com/forum/showthread.php?tid=2793
I am trying to upload code with Arduino to my K868 device, but the example codes aren’t working. I followed this guide step by step and the only ting that didn’t work is I couldn’t find where is says ENABLE ESP32 MODE on the webpage. Is this what needs to be done to get Arduino codes working on my K868-A16s? If so, how do I get to the Ethernet Settings page that shows this?
Here’s what the guide says:
https://drive.google.com/file/d/1JfgVj3R...sp=sharing
Here’s what the webpage looks like:
https://drive.google.com/file/d/18kRE_hv...sp=sharing
which controller you are using? H32B Pro or A16S? what you want to do?
I ran into the same problem.  I had to make sure the board (NodeMCU-32S) was in bootloader mode.  To do that, hold the "download button" on the KC868-A16S, then press and release the "reset" button.  Then, while still holding the download button, I began the upload in Arduinio IDE.  I waited to release the "download" button until I saw the output of Arduino IDE say "connecting".  Then release the download button.  This sets the processor to the bootloader and will then take your sketch.  Once I did that, it uploaded correctly and worked really well.
2 Guest(s)
