KC868-A8: Read voltage on Analog Input A1 to A4 not working?
Since the Inputs A1 to A4 have an internal pull up resistor the analog voltage should read 3V when the input is open. For some reason I am unable to read the voltage of a open input and it returns 0.075V.
Am I correct that the reading should read around 3V because of the internal Pull-up resistor?
The input config is:
  - platform: adc
    pin: GPIO14
    name: "Analog Input A1"
    update_interval: 5s
What am I doing wrong?
https://www.kincony.com/forum/showthread.php?tid=3499
