11-03-2025, 11:25 PM
* This program controls a 32-channel relay board via two PCF8575 I/O expanders.
* It sequentially turns on each relay and then turns them off in a loop.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
* - 200 milliseconds between switching relays
#include <Wire.h> // Include the Wire library for I2C communication
#include <PCF8575.h> // Include the PCF8575 library to control the I/O expander
#define SDA 8 // Define the SDA pin
#define SCL 18 // Define the SCL pin
#define DELAY_TIME 200 // Define the delay time in milliseconds
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module
#define I2C_ADDRESS_R2 0x26 // I2C address of the second PCF8575 module
#define I2C_ADDRESS_R3 0x27 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 17-32)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 9-16)
PCF8575 pcf8575_R3(I2C_ADDRESS_R3); // Create a PCF8575 object for the second module (for relays 1-8)
Wire.begin(SDA, SCL); // SDA on GPIO 8, SCL on GPIO 18 (according to your board's configuration)
// Initialize serial communication for debugging (optional)
Serial.println("PCF8575 Relay Control: Starting...");
// Initialize the PCF8575 modules
pcf8575_R1.begin();
pcf8575_R2.begin();
pcf8575_R3.begin();
// Turn off all relays initially (set all pins HIGH)
pcf8575_R1.write(i, HIGH); // Set relays 17-32 to OFF (assuming HIGH means OFF for relays)
pcf8575_R2.write(i, HIGH); // Set relays 9-16 to OFF (assuming HIGH means OFF for relays)
pcf8575_R3.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
// Sequentially turn on each relay (1-32)
// First control the relays on the second PCF8575 (relays 1-8, corresponding to pins 8-15)
pcf8575_R3.write(i, LOW); // Turn on the relay at pin i (LOW means ON for the relay)
delay(DELAY_TIME); // Wait for DELAY_TIME milliseconds
// First control the relays on the second PCF8575 (relays 9-16, corresponding to pins 8-15)
pcf8575_R2.write(i, LOW); // Turn on the relay at pin i (LOW means ON for the relay)
// Then control the relays on the first PCF8575 (relays 17-32)
pcf8575_R1.write(i, LOW); // Turn on the relay at pin i (LOW means ON for the relay)
// Sequentially turn off each relay (1-24)
pcf8575_R3.write(i, HIGH); // Turn on the relay at pin i (LOW means ON for the relay)
pcf8575_R2.write(i, HIGH); // Turn off the relay at pin i (HIGH means OFF for the relay)
pcf8575_R1.write(i, HIGH); // Turn off the relay at pin i (HIGH means OFF for the relay)
1-relay.zip (Size: 1.08 KB / Downloads: 437)
1-relay.ino.merged.zip (Size: 197.73 KB / Downloads: 449)
