* SD Card File Operations
* Hardware Connections:
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK 11
#define MISO 12
#define MOSI 10
#define CS 9
File file = fs.open(path);
if (!file) {
return;
while (file.available()) {
file.close();
if (!file) {
return;
if (file.print(message)) {
} else {
file.close();
if (!file) {
return;
} else {
file.close();
void deleteFile(fs::FS &fs, const char * path) {
if (fs.remove(path)) {
} else {
static uint8_t buf[512];
size_t len = 0;
uint32_t start = millis();
uint32_t end = start;
if (file) {
len = file.size();
size_t flen = len;
start = millis();
while (len) {
size_t toRead = len;
if (toRead > 512) {
toRead = 512;
file.read(buf, toRead);
len -= toRead;
end = millis() - start;
file.close();
} else {
if (!file) {
return;
size_t i;
start = millis();
for (i = 0; i < 2048; i++) {
file.write(buf, 512);
file.close();
// Initialize SPI and SD card
return;
if (cardType == CARD_NONE) {
return;
if (cardType == CARD_MMC) {
Serial.println("MMC");
Serial.println("SDSC");
Serial.println("SDHC");
} else {
Serial.println("UNKNOWN");
delay(2000);
// Perform file operations
deleteFile(SD, "/hello.txt");
readFile(SD, "/hello.txt");
testFileIO(SD, "/test.txt");
// No operation in loop
6-SD.zip (Size: 1.53 KB / Downloads: 741)
