11-03-2025, 11:41 PM
* Description:
* This Arduino program reads the state of a 16-channel PCF8574 I/O expander
* each pin is represented as a bit in a 8-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 21
* - SCL: GPIO 22
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8574.h"
// Define I2C pins
#define I2C_SDA 8 // Define SDA pin
#define I2C_SCL 18 // Define SCL pin
// Set I2C address
PCF8574 pcf8574_IN1(0x24); // The I2C address of the PCF8575
pcf8574_IN1.pinMode(P0, INPUT);
pcf8574_IN1.pinMode(P1, INPUT);
pcf8574_IN1.pinMode(P2, INPUT);
pcf8574_IN1.pinMode(P3, INPUT);
pcf8574_IN1.begin(); // Initialize the PCF8575
Serial.println("KinCony F4 4 channel input state 0:ON 1:OFF");
uint16_t state = 0;
for (int pin = 0; pin < 4; pin++) {
if (pcf8574_IN1.digitalRead(pin)) {
delay(500); // Delay 500ms
2-digital-input.zip (Size: 879 bytes / Downloads: 465)
2-digital-input.ino.merged.zip (Size: 199.53 KB / Downloads: 519)
