* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 48
* - GPIO 47
* - GPIO 21
* - GPIO 15
* - GPIO 14
* - GPIO 13
* - GPIO 12
* - GPIO 40
* Hardware Requirements:
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_21 21
#define GPIO_PIN_15 15
#define GPIO_PIN_14 14
#define GPIO_PIN_13 13
#define GPIO_PIN_12 12
#define GPIO_PIN_40 40
while (!Serial); // Wait for the serial monitor to open
pinMode(GPIO_PIN_48, INPUT);
pinMode(GPIO_PIN_47, INPUT);
pinMode(GPIO_PIN_21, INPUT);
pinMode(GPIO_PIN_15, INPUT);
pinMode(GPIO_PIN_14, INPUT);
pinMode(GPIO_PIN_13, INPUT);
pinMode(GPIO_PIN_12, INPUT);
pinMode(GPIO_PIN_40, INPUT);
bool currentState[8];
currentState[0] = digitalRead(GPIO_PIN_48);
currentState[1] = digitalRead(GPIO_PIN_47);
currentState[2] = digitalRead(GPIO_PIN_21);
currentState[3] = digitalRead(GPIO_PIN_15);
currentState[4] = digitalRead(GPIO_PIN_14);
currentState[5] = digitalRead(GPIO_PIN_13);
currentState[6] = digitalRead(GPIO_PIN_12);
currentState[7] = digitalRead(GPIO_PIN_40);
for (int i = 0; i < 8; i++) {
Serial.print("GPIO ");
Serial.print(i == 0 ? GPIO_PIN_48 :
i == 1 ? GPIO_PIN_47 :
i == 2 ? GPIO_PIN_21 :
i == 3 ? GPIO_PIN_15 :
i == 4 ? GPIO_PIN_14 :
i == 5 ? GPIO_PIN_13 :
i == 6 ? GPIO_PIN_12 : GPIO_PIN_40);
Serial.print(" changed to ");
// Update the previous state
5-free-gpio-state.zip (Size: 1.05 KB / Downloads: 776)
5-free-gpio-state.ino.merged.zip (Size: 177.49 KB / Downloads: 805)
