* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
byte year; // Last two digits of the year, library adds 2000.
byte month;
byte day;
byte hour;
byte minute;
byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA 26
#define OPEN_RLY_MONTH 4
#define CLOSE_RLY_DATA 2
#define CLOSE_RLY_MONTH 5
// Define pin connections
#define SDA_PIN 8
#define SCL_PIN 18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
Serial.print(year);
Serial.print("-");
Serial.print("-");
Serial.print(" ");
Serial.print(":");
Serial.print(":");
static void GetSerialCmd()
if (Serial.available() > 0)
delay(100);
while (num_read--)
else return;
serial_cmd_rcv.trim();
PrintfCurTime();
return;
Serial.print("D index: ");
Serial.print(indexof_d);
Serial.print(" T index: ");
Serial.println(indexof_t);
return;
rtc.setDate(my_date_str.day);
Serial.println("Time set.");
PrintfCurTime();
while (Serial.read() >= 0) {}
GetSerialCmd();
7-DS3231-RTC.zip (Size: 1.51 KB / Downloads: 794)
7-DS3231-RTC.ino.merged.zip (Size: 189.06 KB / Downloads: 767)
