Home Assistant Setup with Voice, Tablet & App Control Using KinCony ESP32 Relay Board
Hi everyone! This is my first post here — excited to join the community and learn from all of you. Looking forward to sharing ideas and getting your advice.
I would like to set up a system using Home Assistant, which will be controlled by voice commands, as well as via a tablet mounted on the wall and a smartphone app.
I found your device KinCony F32 ESP32-S3 16A Removable Relay Board released, and here is the question: is this device capable of handling all the listed components?
I am at the stage of cable routing in the house:
1. 3x2.5 cables for power outlets
2. 3x1.5 cables for light bulbs
3. Ethernet Cat 5 cables for switches/buttons that will control the bulbs
4. Ethernet Cat 5 cables for sensors
5. Ethernet Cat 6 cables for 6 reolink cameras
6. Ethernet Cat 5 cables for sensors/detectors
7. LED cables for lighting
8. 3x1.5 cable for garden lamps
9. 3x2.5 cable for the deep well pump
10. Underground cable 11x1 for the irrigation system
11. 3x1.5 cable for external blinds
12. 3x2.5 cable that in the future may be used for more powerful garden equipment
13. 3x2.5 cable for the sliding entrance gate and a separate cable for the garage gate.
    Additionally, a LAN network and 2 APs will be installed in the house.
The devices I want to connect to your system are:
1. Hitachi heat pump model Yutaki S8kW, for water heating and underfloor heating on the ground floor and first floor.
2. Domekt R450V LA/Z ventilation system (heat recovery).
3. 2 separate air conditioning units and an additional air conditioning unit that will support the ventilation system.
4. Cameras, NVR Frigate with CORAL AI module.
5. 11 external blinds on Yooda motors that can be connected to a micro control panel 1-channel DC 73 and wall remotes DC 315.
6. Irrigation system with 10 zones.
7. Entrance and garage gates.
8. Photovoltaic panels with an energy storage system.
9. All lighting points:
    16 zones in the house, 2 zones will have staircase switches. Additionally, some places will have LED strips installed.
10. Sensors:
- Presence/motion sensors
- Door/window opening sensors (contact sensors)
- Vibration sensors
- Smoke detectors
- Flood sensors
- CO detectors
- Temperature and humidity sensors
- Wind and rain sensors
Connection diagram:
Distribution board number 1 will contain only "power outlets," and all 3x2.5 cables are routed here. Initially, I did not consider integrating them with smart/automation solutions, but if this is possible, I will consider it. Additionally, the photovoltaic installation will also be connected here.
Distribution board number 2 will contain everything else listed.
Both distribution boards are located in different rooms.
How to connect these 2 distribution boards using your solution?
Can you recommend your sensors and everything needed to assemble this system?
All recommendations, enhancements, and any tips are highly welcome.
-- just every board connect to router by ethernet cable or wifi. they are in same network, so that can use by one software application.
-- our board support DS18B20 / DHT11 / DHT22 / SHT31 / KinCony TS RS485 sensor.
whether the channels of relay whether enough, you can check product details at here:
https://mq.kincony.com/qq/product/product-selector
