[arduino code examples for B4M]-04 RS485 communication test
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 39
#define RS485_TXD 38
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B8M!");
  // Wait for a short period
  delay(1000);
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 408)
.zip   4-RS485-Test.ino.merged.zip (Size: 190.13 KB / Downloads: 394)
