[arduino code examples for B32M]-10 Print TEXT on SSD1306 OLED displayer
* This Arduino program demonstrates how to display text on an SSD1306 128x64 OLED display using the U8g2 library.
* The program draws two lines of text on the display:
* - The first line is "KINCONY" in a larger font.
* - The second line is "www.kincony.com" in a smaller font.
* The display is connected via I2C (software implementation) with:
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
* The display's I2C address is set to 0x3C.
#include <U8g2lib.h>  // Include the U8g2 library for controlling the OLED display
#include <Wire.h>     // Include the Wire library for I2C communication
// Initialize the display using the software I2C method (SCL = IO18, SDA = IO8)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  18, 8, U8X8_PIN_NONE);  // Screen rotation: U8G2_R0
// Function to display page 1 content
void page1() {
  // Set font size 18 for the larger "KINCONY" text
  u8g2.setFont(u8g2_font_timR18_tf);  // Use the Times Roman font, size 18
  u8g2.setFontPosTop();               // Set the text position at the top of the display
  u8g2.setCursor(5, 0);               // Position the cursor at coordinates (5, 0)
  u8g2.print("KINCONY");              // Display the text "KINCONY" on the screen
  // Set font size 12 for the smaller "www.kincony.com" text
  u8g2.setFont(u8g2_font_timR12_tf);  // Use the Times Roman font, size 12
  u8g2.setCursor(0, 40);              // Position the cursor at coordinates (0, 40)
  u8g2.print("www.kincony.com");      // Display the text "www.kincony.com"
  // Set the I2C address for the display to 0x3C
  u8g2.setI2CAddress(0x3C*2);  // I2C address shift for 8-bit format
  u8g2.begin();
  // Enable UTF-8 character printing for the display
  u8g2.enableUTF8Print();  // Allow UTF-8 encoded text to be printed
// Main loop function, continuously runs after setup()
  // Begin the display drawing process
  u8g2.firstPage();  // Prepare the first page for drawing
  do {
    // Call the page1() function to draw content on the display
    page1();
  } while (u8g2.nextPage());  // Continue to the next page until all pages are drawn
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 713)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 202.58 KB / Downloads: 741)
(07-31-2025, 07:06 AM)admin Wrote: BIN file (you can use esp32 download tool download to ESP32-S3 with address 0x0 then directly to use) download:
Can you tell please:
1) I already have a B24M firmware for ESPhome onboard my B24M. At the same time I should only download a bin file (adding to my existing firmware)?
2) How can I print on the screen data from DHT22 (temperature and humidity)? where I can take code for these issue?
1. Yes, just download KCS v3 firmware by usb-c cable. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
2. after you downloaded KCS v3 firmware, add the DHT22 and enable show in display option. here is photo.
[Image: sensor-webpage.png]
(01-21-2026, 11:15 PM)admin Wrote: 1. Yes, just download KCS v3 firmware by usb-c cable. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
But I dont want KCS firmware, I am ascking about ESPhome firmware, already installed via yaml file. Can I add bin file to my ESPhome firmware?
The DHT22 displaing alsow about ESPhome firmware Smile
thanks)
if you using ESPhome, just download ESPHome firmware, not need download KCS firmware. if you want show temperature value on SSD1306, please see ESPHome online guide: https://esphome.io/components/display/ssd1306/
there is an example about show voltage on SSD1306, you can chnage it: https://www.kincony.com/forum/showthread.php?tid=3088
