ESP32 Smart Controller – B4 (4CH Relay) Schematic
Hi,
Is a schematic available for the "ESP32 Smart Controller – B4 (4CH Relay)"?
Kind regards,
Anne
sorry, only have esp32 pin define: https://www.kincony.com/forum/showthread.php?tid=8913
(03-20-2026, 08:37 AM)admin Wrote: sorry, only have esp32 pin define: https://www.kincony.com/forum/showthread.php?tid=8913
That's a pity. Could you tell me the resistor value used for the 1-wire GPIOs (with pull-up resistors on the PCB)?
Thanks in advance!
kind regards,
Anne
pull-up resistors use 10k
(03-20-2026, 11:07 AM)admin Wrote: pull-up resistors use 10k
It is really a pitty, the schematics for other boards are published, but I do not understand, why not for this.
Are the outputs of the B4M etc. esp32 smart controllers protected by a flyback diode, so I can drive solenoid electronic locks without damaging the mosfets.
B4M mosfet output can drive solenoid electronic locks directly.
