here is sample ESPHome yaml code for 3 TS together with one RS485 bus using KC868-A16v3 board.
set every TS with different RS485 address by PC software, make sure PC software can read the data:
here is ESPHome yaml
download yaml:
TS-HA.txt (Size: 3.45 KB / Downloads: 287)
firmware download:
TS_V10Build241223SP0518.zip (Size: 10.25 KB / Downloads: 352)
friendly_name: a16v3_ts
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO15
interrupt_pin: GPIO2
reset_pin: GPIO1
uart:
- id: uart_RS485
baud_rate: 9600
tx_pin: 16
rx_pin: 17
modbus:
- id: modbus_ts
uart_id: uart_RS485
send_wait_time: 50ms
# Sensor 1 - Address 1
modbus_controller:
- id: ts_sensor_1
modbus_id: modbus_ts
address: 0x01
command_throttle: 200ms
setup_priority: -10
update_interval: 10s
- id: ts_sensor_2
address: 0x02
setup_priority: -10
- id: ts_sensor_3
address: 0x03
setup_priority: -10
# Sensor 1 Temperature (Address 1)
- platform: modbus_controller
modbus_controller_id: ts_sensor_1
name: "TS Sensor 1 Temperature"
register_type: holding
address: 0x0000
unit_of_measurement: "°C"
accuracy_decimals: 1
value_type: U_WORD
filters:
- lambda: |-
if (x >= 10000) {
return -1 * (x - 10000) * 0.1;
} else {
return x * 0.1;
# Sensor 1 Humidity (Address 1)
name: "TS Sensor 1 Humidity"
address: 0x0001
unit_of_measurement: "%RH"
value_type: U_WORD
filters:
- lambda: return x * 0.1;
# Sensor 2 - Address 2
# Sensor 2 Temperature (Address 2)
modbus_controller_id: ts_sensor_2
name: "TS Sensor 2 Temperature"
address: 0x0000
value_type: U_WORD
filters:
- lambda: |-
if (x >= 10000) {
} else {
return x * 0.1;
# Sensor 2 Humidity (Address 2)
name: "TS Sensor 2 Humidity"
address: 0x0001
value_type: U_WORD
filters:
# Sensor 3 - Address 3
# Sensor 3 Temperature (Address 3)
modbus_controller_id: ts_sensor_3
name: "TS Sensor 3 Temperature"
address: 0x0000
value_type: U_WORD
filters:
- lambda: |-
if (x >= 10000) {
} else {
return x * 0.1;
# Sensor 3 Humidity (Address 3)
name: "TS Sensor 3 Humidity"
address: 0x0001
value_type: U_WORD
filters:
web_server:
port: 80download yaml:
firmware download:
