[arduino code examples for CO16]-09 digital INPUT trigger OUTPUT directly
  Program functionality:
  This program uses ESP32-S3 to read inputs from PCA9555 I/O expander chip (I2C address 0x24)
  for channels 1-16, and control corresponding relays using PCF8575 I/O expander chip (I2C address 0x22)
  for controlling 16 relays (1-16). When input (DI) is triggered (LOW), corresponding relay (OUTPUT) is activated (LOW).
#include <PCA95x5.h>
#include <Wire.h>
#include <PCF8575.h>
// Initialize the PCA9555 objects for reading inputs (channels 1-16)
PCA9555 input_ioex1;  // For channels 1-16 (I2C address 0x24)
// Set I2C address of the PCF8575 module for output relays
#define I2C_ADDRESS 0x22
PCF8575 pcf8575_R1(I2C_ADDRESS);
    delay(10);
    // Initialize I2C bus: SDA=GPIO8, SCL=GPIO18, 100kHz
    Wire.begin(8, 18, 100000);
    // Initialize PCF8575 for outputs
    pcf8575_R1.begin();
    // Turn off all relays initially (set all pins HIGH - relay OFF)
        pcf8575_R1.write(i, HIGH);
    // Configure input PCA9555 (for inputs 1-16)
    input_ioex1.attach(Wire, 0x24);
    input_ioex1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
    input_ioex1.direction(PCA95x5::Direction::IN_ALL);
    delay(50);
    // Read input states from XL9535 (inputs 1-16)
    uint16_t inputs_1_16 = input_ioex1.read();
    // Control outputs based on inputs
    // When input is LOW, set corresponding output to LOW (activate relay)
    for (int channel = 0; channel < 16; channel++) {
        if (!(inputs_1_16 & (1 << channel))) {
            pcf8575_R1.write(channel, LOW);   // Input triggered, activate relay
        } else {
            pcf8575_R1.write(channel, HIGH);  // Input not triggered, deactivate relay
    delay(100);
.zip   9-input-trigger-output.zip (Size: 997 bytes / Downloads: 135)
.zip   9-input-trigger-output.ino.merged.zip (Size: 197.75 KB / Downloads: 141)
