getting the A8A inputs to work?
Hello!
i have a Kincony A8 i finally try to get working....
the relais i got working, but the inputs don't....
i flashed from esphome the follwoing:
  friendly_name: relais_wohnung
esp32:
  variant: esp32
  board: esp32dev
  framework:
    type: arduino
# I2C Bus für die Relais-Ansteuerung
  sda: GPIO4
  scl: GPIO5
pcf8574:
  - id: pcf8574_hub_in_1
    address: 0x22
    pcf8575: false
    name: "A8 Input 1"
      pcf8574: pcf8574_hub_in_1
      mode: INPUT
    name: "A8 Input 2"
      number: 1
      mode: INPUT
    name: "A8 Input 3"
      number: 2
      mode: INPUT
    name: "A8 Input 4"
      number: 3
      mode: INPUT
    name: "A8 Input 5"
      number: 4
      mode: INPUT
    name: "A8 Input 6"
      number: 5
      mode: INPUT
    name: "A8 Input 7"
      number: 6
      mode: INPUT
    name: "A8 Input 8"
      number: 7
      mode: INPUT
  encryption:
    key: "*****"
ota:
  - platform: esphome
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    mode: CLK_OUT
    pin: 17
  phy_addr: 0
i tried to put common the pin 3, on GND, then 12V, then GND again.... i tried directly to put 12V or GND, when inversed, with a wire directly to the contacts, not a peep? what am i doing wrong?
i thought that electrically speaking i go 12V to the houe bell switch, back to the input entry, and put the 12V- GND on common? but that simply doesn't do it?
you can take a photo how you wire?
i don't understand which pin on PCB are you are using.
(09-19-2026, 01:41 AM)admin Wrote: you can take a photo how you wire?
ok! here's the photo:
comletely left is the power supply then 12V GND and in front you see the floating +12V i use to poke the inputs and rightmost of the inputs bar is the ocnnection to the +12V coming from the doorbell...
https://www.pasteboard.co/Bc9C0u3-Vr7B.jpg
digital input =0v means trigger.
so i have GND on the common input row? and if i put an input to 0 it triggers? seems strange....
tried...
my code still doesn't report anything?
i suggest you download KCS firmware test DI firstly. if work well, then config by ESPHome.
