[arduino code examples for B2]-12 send Short Message (SMS) to mobile phone by SIM7600
* Send one SMS through SIM7600 using AT commands.
* SIM7600 RXD -> ESP32 GPIO16 (TX)
* SIM7600 TXD -> ESP32 GPIO15 (RX)
#include <Arduino.h>
HardwareSerial modem(2);
constexpr int MODEM_RX = 15;
constexpr int MODEM_TX = 16;
constexpr uint32_t MODEM_BAUD = 115200;
const char PHONE_NUMBER[] = "+8615381188302";
const char SMS_TEXT[] = "kincony";
// Read modem responses and mirror them to the USB serial port.
bool waitFor(const char *expected, uint32_t timeoutMs) {
  String response;
  uint32_t start = millis();
  while (millis() - start < timeoutMs) {
    while (modem.available()) {
      char c = modem.read();
      Serial.write(c);
      response += c;
      if (response.indexOf(expected) >= 0) {
        return true;
      if (response.indexOf("ERROR") >= 0) {
        return false;
    delay(1);
  Serial.println("\n[Timeout]");
  return false;
bool sendAT(const String &command,
            const char *expected = "OK",
            uint32_t timeoutMs = 3000) {
    Serial.write(modem.read());
  Serial.print("\n>> ");
  Serial.println(command);
  modem.print(command);
  modem.print('\r');
  return waitFor(expected, timeoutMs);
  modem.begin(MODEM_BAUD, SERIAL_8N1, MODEM_RX, MODEM_TX);
  Serial.println("\nWaiting for SIM7600...");
  // Allow time for module startup and network registration.
  delay(15000);
  bool modemReady = false;
  for (int i = 0; i < 10; i++) {
    if (sendAT("AT")) {
      modemReady = true;
      break;
    delay(1000);
  if (!modemReady) {
    Serial.println("No modem response. Check power, baud rate and UART pins.");
    return;
  if (!sendAT("ATE0")) return;
  if (!sendAT("AT+CPIN?", "+CPIN: READY")) {
    Serial.println("SIM card is not ready.");
    return;
  // Print signal strength and registration status for diagnosis.
  sendAT("AT+CSQ");
  sendAT("AT+CREG?");
  sendAT("AT+CEREG?");
  // Configure SMS text mode and GSM character set.
  if (!sendAT("AT+CMGF=1")) return;
  if (!sendAT("AT+CSCS=\"GSM\"")) return;
  String command = String("AT+CMGS=\"") + PHONE_NUMBER + "\"";
  if (!sendAT(command, ">", 10000)) {
    Serial.println("SMS input prompt was not received.");
    return;
  modem.print(SMS_TEXT);
  modem.write((uint8_t)0x1A);  // Ctrl+Z submits the SMS.
  // Do not retry automatically: this avoids duplicate messages.
  if (waitFor("+CMGS:", 120000)) {
    Serial.println("\nSMS submitted successfully.");
  } else {
    Serial.println("\nSMS failed or result is unknown. Check modem output.");
  // UART bridge for manual AT-command debugging.
  while (Serial.available()) {
    modem.write(Serial.read());
.zip   12-send-SMS.zip (Size: 1.34 KB / Downloads: 29)
.zip   12-send-SMS.ino.merged.zip (Size: 186.84 KB / Downloads: 29)
