[arduino code examples for B2]-13 voice call to mobile phone by SIM7600
* Make a voice call using SIM7600 AT commands.
* SIM7600 RXD -> ESP32 GPIO16 (TX)
* SIM7600 TXD -> ESP32 GPIO15 (RX)
#include <Arduino.h>
HardwareSerial modem(2);
constexpr int MODEM_RX = 15;
constexpr int MODEM_TX = 16;
constexpr uint32_t MODEM_BAUD = 115200;
// Time from starting the call until automatic hang-up.
constexpr uint32_t CALL_DURATION_MS = 30000;
const char PHONE_NUMBER[] = "+8615381188302";
bool waitFor(const char *expected, uint32_t timeoutMs) {
  String response;
  uint32_t start = millis();
  while (millis() - start < timeoutMs) {
    while (modem.available()) {
      char c = modem.read();
      Serial.write(c);
      response += c;
      if (response.indexOf(expected) >= 0) {
        return true;
      if (response.indexOf("ERROR") >= 0 ||
          response.indexOf("NO CARRIER") >= 0 ||
          response.indexOf("BUSY") >= 0 ||
          response.indexOf("NO ANSWER") >= 0) {
        return false;
    delay(1);
  Serial.println("\n[Timeout]");
  return false;
bool sendAT(const String &command,
            const char *expected = "OK",
            uint32_t timeoutMs = 3000) {
    Serial.write(modem.read());
  Serial.print("\n>> ");
  Serial.println(command);
  modem.print(command);
  modem.print('\r');
  return waitFor(expected, timeoutMs);
  modem.begin(MODEM_BAUD, SERIAL_8N1, MODEM_RX, MODEM_TX);
  Serial.println("\nWaiting for SIM7600...");
  delay(15000);
  bool modemReady = false;
  for (int i = 0; i < 10; i++) {
    if (sendAT("AT")) {
      modemReady = true;
      break;
    delay(1000);
  if (!modemReady) {
    Serial.println("No modem response. Check power, baud rate and UART pins.");
    return;
  if (!sendAT("ATE0")) return;
  if (!sendAT("AT+CPIN?", "+CPIN: READY")) {
    Serial.println("SIM card is not ready.");
    return;
  // Print signal strength and network registration status.
  sendAT("AT+CSQ");
  sendAT("AT+CREG?");
  sendAT("AT+CEREG?");
  // A trailing semicolon requests a voice call.
  String dialCommand = String("ATD") + PHONE_NUMBER + ";";
  Serial.println("\nDialing...");
  uint32_t callStart = millis();
  if (!sendAT(dialCommand, "OK", 10000)) {
    Serial.println("\nDial command failed or timed out.");
    sendAT("ATH");
    return;
  Serial.println("\nDial command accepted; waiting for call events.");
  String line;
  bool callEnded = false;
  while (millis() - callStart < CALL_DURATION_MS && !callEnded) {
      Serial.write(c);
      if (c == '\n') {
        line.trim();
        if (line == "NO CARRIER" ||
            line == "BUSY" ||
            line == "NO ANSWER" ||
            line == "ERROR") {
          callEnded = true;
        line = "";
      } else if (c != '\r') {
        line += c;
    delay(1);
  if (callEnded) {
    Serial.println("\nCall ended.");
  } else {
    Serial.println("\nHanging up...");
    sendAT("ATH");
  // UART bridge for manual AT-command debugging.
  while (Serial.available()) {
    modem.write(Serial.read());
.zip   13-4G-call.zip (Size: 1.36 KB / Downloads: 45)
.zip   13-4G-call.ino.merged.zip (Size: 187.34 KB / Downloads: 47)
