[arduino code examples for T16M]-01 Turn ON/OFF OUTPUT by 9555 chip
* This program controls a 16-channel relay board via an XL9555
* I/O expander using the PCA95x5 library.
* It sequentially turns ON all 16 relays, then sequentially
* turns them OFF, repeating continuously.
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* I2C Address:
* - XL9555: 0x25
* Relay Logic:
* - LOW  = ON
* - HIGH = OFF
* Switching Interval:
* - 200 milliseconds
#include <Wire.h>
#include <PCA95x5.h>
#define I2C_SDA_PIN  11
#define I2C_SCL_PIN  12
#define I2C_ADDRESS  0x25
#define DELAY_TIME   200
#define RELAY_COUNT  16
// Use the PCA9555 driver for the XL9555 I/O expander.
PCA9555 relayIO;
  // Initialize serial communication.
  // Initialize I2C: SDA = GPIO11, SCL = GPIO12, clock = 100 kHz.
  Wire.begin(I2C_SDA_PIN, I2C_SCL_PIN, 100000);
  Serial.println("XL9555 Relay Control: Starting...");
  // Attach the XL9555 to the I2C bus.
  relayIO.attach(Wire, I2C_ADDRESS);
  // Disable input polarity inversion.
  relayIO.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
  // Preload all output latches HIGH before enabling outputs.
  // HIGH keeps the active-low relays OFF.
  relayIO.write(PCA95x5::Level::H_ALL);
  // Configure all 16 ports as outputs.
  relayIO.direction(PCA95x5::Direction::OUT_ALL);
  delay(50);
  Serial.println("All relays initialized to OFF.");
  // Sequentially turn ON relays 1-16.
  for (int i = 0; i < RELAY_COUNT; i++) {
    relayIO.write(
      (PCA95x5::Port::Port)i,
      PCA95x5::Level::L
    Serial.print("Relay ");
    Serial.print(i + 1);
    Serial.println(" ON");
    delay(DELAY_TIME);
  // Sequentially turn OFF relays 1-16.
    relayIO.write(
      PCA95x5::Level::H
    Serial.println(" OFF");
    delay(DELAY_TIME);
.zip   1-output-9555.zip (Size: 1,016 bytes / Downloads: 28)
.zip   1-output-9555.ino.merged.zip (Size: 194.16 KB / Downloads: 28)
