[arduino code examples for T16M]-02 Read digital input ports state by 9555 chip
* Description:
* This Arduino program reads 16 digital inputs from an XL9555
* I/O expander using the PCA95x5 library.
* Input states are printed as a fixed-width 16-bit binary value:
* - Leftmost bit:  CH16 (port 15)
* - Rightmost bit: CH1  (port 0)
* - 0 = ON
* - 1 = OFF
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* - XL9555 I2C Address: 0x24
* Read Interval:
* - 500 milliseconds
#include <Arduino.h>
#include <Wire.h>
#include <PCA95x5.h>
// Define I2C pins and device address.
#define I2C_SDA      11
#define I2C_SCL      12
#define I2C_ADDRESS  0x24
// Use the PCA9555 driver for the XL9555 I/O expander.
PCA9555 inputIO;
    // Initialize I2C: SDA = GPIO11, SCL = GPIO12, clock = 100 kHz.
    Wire.begin(I2C_SDA, I2C_SCL, 100000);
    // Attach the XL9555 to the I2C bus.
    inputIO.attach(Wire, I2C_ADDRESS);
    // Read the original input levels without polarity inversion.
    inputIO.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
    // Configure all 16 ports as inputs.
    inputIO.direction(PCA95x5::Direction::IN_ALL);
    delay(50);
    Serial.println("KinCony XL9555 16-channel input test");
    Serial.println("0 = ON, 1 = OFF");
    Serial.println("Bit order: CH16 ... CH1");
    // Read all 16 input ports.
    uint16_t state = inputIO.read();
    // Print all 16 bits, including leading zeros.
    for (int bit = 15; bit >= 0; bit--) {
        Serial.print((state >> bit) & 0x01);
    Serial.println();
    delay(500);
.zip   2-digital-input-9555.zip (Size: 992 bytes / Downloads: 37)
.zip   2-digital-input-9555.ino.merged.zip (Size: 194.18 KB / Downloads: 32)
