# Made by KinCony IoT: https://www.kincony.com
# T16M with XL9555 I/O expanders, using the compatible xl9535 driver.
# Channel 1-8: pins 0-7 (P00-P07).
# Channel 9-16: pins 10-17 (P10-P17), NOT pins 8-15.
friendly_name: t16m
esp32:
board: esp32-s3-devkitc-1
framework:
type: arduino
type: W5500
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
- id: bus_a
sda: 11
scl: 12
frequency: 400kHz
xl9535:
- id: xl9555_hub_out_1
i2c_id: bus_a
address: 0x25
- id: xl9555_hub_in_1
i2c_id: bus_a
address: 0x24
uart:
- id: uart_1
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 13
rx_pin: 14
- platform: uart
uart_id: uart_1
xl9535: xl9555_hub_out_1
mode: OUTPUT
number: 1
mode: OUTPUT
number: 2
mode: OUTPUT
number: 3
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
number: 10
mode: OUTPUT
number: 11
mode: OUTPUT
number: 12
mode: OUTPUT
number: 13
mode: OUTPUT
number: 14
mode: OUTPUT
number: 15
mode: OUTPUT
number: 16
mode: OUTPUT
number: 17
mode: OUTPUT
xl9535: xl9555_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
number: 6
mode: INPUT
number: 7
mode: INPUT
number: 10
mode: INPUT
number: 11
mode: INPUT
number: 12
mode: INPUT
number: 13
mode: INPUT
number: 14
mode: INPUT
number: 15
mode: INPUT
number: 16
mode: INPUT
number: 17
mode: INPUT
# External pull-up resistors are installed on the PCB.
number: 8
number: 9
number: 10
number: 15
number: 16
inverted: false
number: 17
inverted: false
number: 18
inverted: false
inverted: false
web_server:
port: 80
T16M-HA-XL9555.txt (Size: 7.28 KB / Downloads: 16)
