[arduino code examples for CO16]-12 ST7789 TFT LCD image display
* CO16 Image Display - show the supplied photograph on the onboard LCD.
* Target: ESP32-S3 CO16, ST7789 320x240 landscape.
* Uses the display initialization from the validated CO16 Cyber Show sketch.
* Install Adafruit GFX Library and its Adafruit BusIO dependency.
* Select ESP32S3 Dev Module; retain your working CO16 board settings.
* Keep image_data.h in the same folder as this sketch.
* Image is stored in flash as RGB565; no SD card, JPEG decoder or Wi-Fi.
* Full image is resized to 320x240 with no margins; aspect ratio changes.
* PCF8575 relay outputs at 0x22 are commanded OFF at startup.
#include <Arduino.h>
#include <Wire.h>
#include "image_data.h"
#include <Adafruit_GFX.h>
#include <driver/gpio.h>
#include <driver/spi_master.h>
#include <esp_heap_caps.h>
// CO16 ST7789 (GMT020-02-7P) pin mapping from kcs_co16.h.
constexpr gpio_num_t kTftSclk = GPIO_NUM_11;
constexpr gpio_num_t kTftMosi = GPIO_NUM_10;
constexpr gpio_num_t kTftMiso = GPIO_NUM_12;
constexpr gpio_num_t kTftCs = GPIO_NUM_4;
constexpr gpio_num_t kTftDc = GPIO_NUM_0;
constexpr gpio_num_t kTftReset = GPIO_NUM_5;
constexpr gpio_num_t kTftBacklight = GPIO_NUM_40;
constexpr int16_t kDisplayWidth = 320;
constexpr int16_t kDisplayHeight = 240;
constexpr int16_t kTransferChunkHeight = 10;
constexpr uint32_t kDisplaySpiFrequency = 20 * 1000 * 1000;
constexpr uint8_t kCo16Madctl = 0x68;  // MX | MV | BGR.
constexpr uint16_t kBlack = 0x0000;
constexpr uint16_t kBlue = 0x001F;
constexpr uint16_t kRed = 0xF800;
constexpr uint16_t kGreen = 0x07E0;
constexpr uint16_t kCyan = 0x07FF;
constexpr uint16_t kMagenta = 0xF81F;
constexpr uint16_t kYellow = 0xFFE0;
constexpr uint16_t kWhite = 0xFFFF;
class Co16St7789 : public Adafruit_GFX {
public:
  Co16St7789() : Adafruit_GFX(kDisplayWidth, kDisplayHeight) {}
  bool begin() {
    gpio_reset_pin(kTftCs);
    gpio_set_direction(kTftCs, GPIO_MODE_OUTPUT);
    gpio_set_level(kTftCs, 1);
    gpio_reset_pin(kTftDc);
    gpio_set_direction(kTftDc, GPIO_MODE_OUTPUT);
    gpio_set_level(kTftDc, 1);
    gpio_reset_pin(kTftBacklight);
    gpio_set_direction(kTftBacklight, GPIO_MODE_OUTPUT);
    gpio_set_level(kTftBacklight, 0);
    spi_bus_config_t busConfig = {};
    busConfig.sclk_io_num = kTftSclk;
    busConfig.mosi_io_num = kTftMosi;
    busConfig.miso_io_num = kTftMiso;
    busConfig.quadwp_io_num = -1;
    busConfig.quadhd_io_num = -1;
    busConfig.max_transfer_sz =
        kDisplayWidth * kTransferChunkHeight * sizeof(uint16_t);
    esp_err_t err =
        spi_bus_initialize(SPI3_HOST, &busConfig, SPI_DMA_CH_AUTO);
    if (err != ESP_OK) {
      Serial.printf("SPI3 initialization failed: %s\n", esp_err_to_name(err));
      return false;
    spi_device_interface_config_t deviceConfig = {};
    deviceConfig.clock_speed_hz = kDisplaySpiFrequency;
    deviceConfig.mode = 0;
    deviceConfig.spics_io_num = -1;
    deviceConfig.queue_size = 1;
    err = spi_bus_add_device(SPI3_HOST, &deviceConfig, &spiDevice_);
      Serial.printf("ST7789 SPI device setup failed: %s\n",
      return false;
    drawBuffer_ = static_cast<uint8_t*>(heap_caps_malloc(
        kDisplayWidth * kTransferChunkHeight * sizeof(uint16_t),
        MALLOC_CAP_DMA));
    if (drawBuffer_ == nullptr) {
      Serial.println("ST7789 DMA buffer allocation failed");
      return false;
    // GPIO5 is shared with the optional LoRa module. Match the working KCS
    // firmware and issue one reset pulse before initializing the controller.
    gpio_reset_pin(kTftReset);
    gpio_set_direction(kTftReset, GPIO_MODE_OUTPUT);
    gpio_set_level(kTftReset, 1);
    delay(1);
    gpio_set_level(kTftReset, 0);
    delay(1);
    delay(10);
    if (!initializeController()) {
      return false;
    fillScreen(kBlack);
    delay(120);
    if (!writeCommand(0x29)) {  // Display on.
      return false;
    delay(120);
    gpio_set_level(kTftBacklight, 1);
    initialized_ = true;
    return true;
  void drawPixel(int16_t x, int16_t y, uint16_t color) override {
    fillRect(x, y, 1, 1, color);
  void writePixel(int16_t x, int16_t y, uint16_t color) override {
  void fillRect(int16_t x, int16_t y, int16_t width, int16_t height,
    if (x < 0) {
      width += x;
      x = 0;
    if (y < 0) {
      height += y;
      y = 0;
    if (x + width > kDisplayWidth) {
      width = kDisplayWidth - x;
    if (y + height > kDisplayHeight) {
      height = kDisplayHeight - y;
    if (drawBuffer_ == nullptr || width <= 0 || height <= 0) {
      return;
    const uint8_t high = color >> 8;
    const uint8_t low = color;
    for (int16_t row = y; row < y + height;
         row += kTransferChunkHeight) {
      const int16_t chunkHeight =
          min<int16_t>(kTransferChunkHeight, y + height - row);
      const size_t pixelCount = width * chunkHeight;
      for (size_t index = 0; index < pixelCount; ++index) {
        drawBuffer_[index * 2] = high;
        drawBuffer_[index * 2 + 1] = low;
      if (!setWindow(x, row, x + width, row + chunkHeight) ||
          !writePixels(drawBuffer_, pixelCount * sizeof(uint16_t))) {
        Serial.println("ST7789 pixel transfer failed");
        return;
  void writeFillRect(int16_t x, int16_t y, int16_t width, int16_t height,
    fillRect(x, y, width, height, color);
  // Copy a fully rendered RGB565 frame into the DMA staging buffer.
  bool present(const uint16_t* pixels) {
    if (!initialized_ || pixels == nullptr) return false;
    for (int y = 0; y < kDisplayHeight; y += kTransferChunkHeight) {
      const int rows = min<int>(kTransferChunkHeight, kDisplayHeight - y);
      const int count = kDisplayWidth * rows;
      for (int i = 0; i < count; ++i) {
        uint16_t c = pixels[y * kDisplayWidth + i];
        drawBuffer_[2 * i] = c >> 8;
        drawBuffer_[2 * i + 1] = c & 0xFF;
      if (!setWindow(0, y, kDisplayWidth, y + rows) ||
          !writePixels(drawBuffer_, count * 2)) return false;
    return true;
  bool initialized() const { return initialized_; }
private:
  bool transmit(const void* data, size_t length, int dcLevel) {
    if (data == nullptr || length == 0) {
      return true;
    gpio_set_level(kTftDc, dcLevel);
    spi_transaction_t transaction = {};
    transaction.length = length * 8;
    transaction.tx_buffer = data;
    const esp_err_t err = spi_device_polling_transmit(spiDevice_, &transaction);
      Serial.printf("ST7789 SPI transfer failed: %s\n", esp_err_to_name(err));
      return false;
    return true;
  bool writeCommand(uint8_t command) {
    gpio_set_level(kTftCs, 0);
    const bool success = transmit(&command, sizeof(command), 0);
    return success;
  bool writeCommandData(uint8_t command, const uint8_t* data, size_t length) {
    const bool success = transmit(&command, sizeof(command), 0) &&
                         transmit(data, length, 1);
    return success;
  bool setWindow(int16_t x1, int16_t y1, int16_t x2, int16_t y2) {
    const uint8_t columns[] = {
        static_cast<uint8_t>(x1 >> 8), static_cast<uint8_t>(x1),
        static_cast<uint8_t>((x2 - 1) >> 8), static_cast<uint8_t>(x2 - 1),
    const uint8_t rows[] = {
        static_cast<uint8_t>(y1 >> 8), static_cast<uint8_t>(y1),
        static_cast<uint8_t>((y2 - 1) >> 8), static_cast<uint8_t>(y2 - 1),
    return writeCommandData(0x2A, columns, sizeof(columns)) &&
           writeCommandData(0x2B, rows, sizeof(rows));
  bool writePixels(const uint8_t* data, size_t length) {
    constexpr uint8_t kRamWrite = 0x2C;
    const bool success = transmit(&kRamWrite, sizeof(kRamWrite), 0) &&
    return success;
  bool initializeController() {
    const uint8_t madctl[] = {kCo16Madctl};
    const uint8_t displayFunction[] = {0x0A, 0x82};
    const uint8_t pixelFormat[] = {0x55};
    const uint8_t porchControl[] = {0x0C, 0x0C, 0x00, 0x33, 0x33};
    const uint8_t gateControl[] = {0x35};
    const uint8_t vcom[] = {0x28};
    const uint8_t lcmControl[] = {0x0C};
    const uint8_t vdvVrhEnable[] = {0x01, 0xFF};
    const uint8_t vrh[] = {0x10};
    const uint8_t vdv[] = {0x20};
    const uint8_t frameRate[] = {0x0F};
    const uint8_t powerControl[] = {0xA4, 0xA1};
    const uint8_t positiveGamma[] = {
        0xD0, 0x00, 0x02, 0x07, 0x0A, 0x28, 0x32,
        0x44, 0x42, 0x06, 0x0E, 0x12, 0x14, 0x17,
    const uint8_t negativeGamma[] = {
        0xD0, 0x00, 0x02, 0x07, 0x0A, 0x28, 0x31,
        0x54, 0x47, 0x0E, 0x1C, 0x17, 0x1B, 0x1E,
    if (!writeCommand(0x11)) {  // Sleep out.
      return false;
    delay(120);
    return writeCommand(0x13) &&
           writeCommandData(0x36, madctl, sizeof(madctl)) &&
           writeCommandData(0xB6, displayFunction, sizeof(displayFunction)) &&
           writeCommandData(0x3A, pixelFormat, sizeof(pixelFormat)) &&
           (delay(10), true) &&
           writeCommandData(0xB2, porchControl, sizeof(porchControl)) &&
           writeCommandData(0xB7, gateControl, sizeof(gateControl)) &&
           writeCommandData(0xBB, vcom, sizeof(vcom)) &&
           writeCommandData(0xC0, lcmControl, sizeof(lcmControl)) &&
           writeCommandData(0xC2, vdvVrhEnable, sizeof(vdvVrhEnable)) &&
           writeCommandData(0xC3, vrh, sizeof(vrh)) &&
           writeCommandData(0xC4, vdv, sizeof(vdv)) &&
           writeCommandData(0xC6, frameRate, sizeof(frameRate)) &&
           writeCommandData(0xD0, powerControl, sizeof(powerControl)) &&
           writeCommandData(0xE0, positiveGamma, sizeof(positiveGamma)) &&
           writeCommandData(0xE1, negativeGamma, sizeof(negativeGamma)) &&
           writeCommand(0x21);  // Display inversion on.
  spi_device_handle_t spiDevice_ = nullptr;
  uint8_t* drawBuffer_ = nullptr;
  bool initialized_ = false;
Co16St7789 display;
  Wire.begin(8, 18);
  Wire.setClock(100000);
  Wire.setTimeOut(20);
  // Active-low PCF8575 relay outputs: HIGH on all channels means OFF.
  Wire.beginTransmission(0x22);
  Wire.write(uint8_t(0xFF));
  if (Wire.endTransmission() != 0) {
    Serial.println("Warning: relay OFF command not acknowledged at 0x22.");
  // Deselect all other SPI peripherals before initializing the LCD bus.
  const int inactiveCs[] = {9, 13, 14, 42};
  for (int pin : inactiveCs) {
    digitalWrite(pin, HIGH);
    pinMode(pin, OUTPUT);
  if (!display.begin()) {
    Serial.println("ST7789 initialization failed.");
    while (true) delay(1000);
  // ESP32 flash is memory mapped. present() reads the constant image into
  // a small DMA-capable staging buffer, then sends it to the ST7789.
  if (!display.present(kImageRgb565)) {
    Serial.println("Image transfer failed.");
  Serial.println("Image displayed: 320x240 RGB565, full-screen image.");
  // The LCD retains its image; no continuous redraw is necessary.
  delay(1000);
.zip   12-CO16_Image_Display.zip (Size: 729.92 KB / Downloads: 4)
.zip   12-CO16_Image_Display.ino.merged.zip (Size: 273.66 KB / Downloads: 3)
