[arduino code examples for F24]-02 Read digital input ports state by XL9555 chip
* Description:
* This Arduino program reads the state of two 16-channel XL9555SS I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor. The state of
* each pin is represented as a bit in a 24-bit value, where each bit corresponds
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - XL9555SS I2C Address: 0x24 for inputs 1-16, 0x26 for inputs 17-24
#include "Arduino.h"
#include <Wire.h>
#include <PCA95x5.h>
// Define I2C pins
constexpr uint8_t INPUT_ADDR_1 = 0x24;
constexpr uint8_t INPUT_ADDR_2 = 0x26;
PCA9555 inputIO1;
PCA9555 inputIO2;
    // Configure both expanders for the input-only test.
    inputIO1.attach(Wire, INPUT_ADDR_1);
    inputIO1.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
    inputIO1.direction(PCA95x5::Direction::IN_ALL);
    // Read only ports 0-7 on 0x26. Leave the relay ports undriven.
    inputIO2.attach(Wire, INPUT_ADDR_2);
    inputIO2.polarity(PCA95x5::Polarity::ORIGINAL_ALL);
    inputIO2.direction(PCA95x5::Direction::IN_ALL);
    Serial.println("KinCony F24 24 channel input state 0:ON  1:OFF");
    // DI1-16 occupy bits 0-15; DI17-24 occupy bits 16-23.
    const uint32_t first = inputIO1.read();
    const uint32_t second = inputIO2.read() & 0x00FFU;
    const uint32_t state = first | (second << 16);
    // Print the state of all 24 inputs in binary format
    delay(500); // Delay 500ms
.zip   2-digital-input-9555.zip (Size: 1 KB / Downloads: 12)
.zip   2-digital-input-9555.ino.merged.zip (Size: 194.2 KB / Downloads: 15)
