Yesterday, 01:23 PM
I'm planning to use a KC868-A16S with ESPHome and Home Assistant, and I would like to confirm that I can connect the 24V DC status output of my motorized gate controller to one of the digital inputs.
Signal source (gate controller DEA NET24N, terminals 12-13 "WARNING"):
My questions:
Thank you very much for your help.
Best regards,
GM from France (I used some help from an AI as English is not my native language)
- Output: 24V DC, max 15 W (designed to drive a gate-status lamp)
- Depending on a parameter, it is either steady while the gate is open, or flashing while the gate is moving
- It is a power-type output meant for a lamp, not a low-current logic signal
- I only need to read this one signal (1 input used)
My questions:
- Can the optocoupled inputs (IN1 to IN16) accept 24V DC directly? Is this within the rated limits of the optocoupler and input circuit?
- What is the maximum input voltage you recommend or guarantee on these inputs?
- The inputs share a common by group of 8. Should I connect the gate controller's 0V to this common? Is this common isolated from the board's 12V supply ground, or are they tied together?
- Is the response time of the inputs and the PCF8574 path suitable for detecting a signal flashing at about 1 to 2 Hz?
- Since the source is a lamp output that may show voltage spikes or ripple (it is not a regulated logic signal), would you recommend any protection on the input (series resistor, TVS diode)?
Best regards,
