home automation training -20-extend digital output & input in home assistant
- extend output and input ports by hardware devicea. KC868-A series board (integrate to home assistant by ESPHome)
b. KC868-HxB series board (integrate to home assistant by MQTT)2. config ESPHome for KC868-A16
platform: ESP32
board: esp32dev# Example configuration entry for ESP32
sda: 4
scl: 5
id: bus_a# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0# Optional manual IP
manual_ip:
static_ip: 192.168.1.199
gateway: 192.168.1.1
subnet: 255.255.255.0# Example configuration entry
– id: ‘pcf8574_hub_out_1’ # for output channel 1-8
address: 0x24– id: ‘pcf8574_hub_out_2’ # for output channel 9-16
address: 0x25– id: ‘pcf8574_hub_in_1’ # for input channel 1-8
address: 0x21– id: ‘pcf8574_hub_in_2’ # for input channel 9-16
address: 0x22# Individual outputs
– platform: gpio
pcf8574: pcf8574_hub_out_1
inverted: true– platform: gpio
pcf8574: pcf8574_hub_out_2
inverted: truebinary_sensor:
– platform: gpio
pcf8574: pcf8574_hub_in_2
inverted: true# Enable logging
logger:# Enable Home Assistant API
