home automation training -9 integrate KC868-Server to home assistant by MQTT
1.MQTT communication structure diagram
KC868-Server——–
publish message: status of switch (status topic)
Subscription message: turn on / off command (command topic)
home assistant——
publish message: turn on / off command (command topic)
Subscription message: status of switch (status topic)
2.KC868-Server digital output , digital input , analog input config sample code in configuration.yaml
# Example configuration.yaml entry
– platform: mqtt
unique_id: output-1
state_topic: ‘server/ xxxxxxxxxxxxxxxxxxxxxxxx /state’
command_topic: ‘server/ xxxxxxxxxxxxxxxxxxxxxxxx /set’
state_on: 1
state_off: 0
– platform: mqtt
unique_id: input-1
value_template: ‘{{ value_json.input1.on }}’
payload_on: 1
payload_off: 0
– platform: mqtt
unique_id: analog-1
unit_of_measurement: ‘v’
value_template: ‘{{ value_json.analog1.value }} ‘
Note: xxxxxxxxxxxxxxxxxxxxxxxx is UID of controller, just replace with your device UID. You can find the UID in ethernet setting.
3.KC868-Server 16 channel output, 16 channel digital input, 4 channel analog input all use in configuration.yaml
KC868-Server-home-assistant-config.txt (Size: 8.15 KB / Downloads: 38)
