home automation training -5 Samba and file structure of HA
Installation, configuration and use of Add-on Samba for home automation DIY
What is Samba?
software tool to realize network file sharing.
Note: before Samba starts, you need to configure the user name and password
Introduction to shared folders
folder content
config Homeassistant configuration directory
backup Store system backup contents
ssl Store the private key and certificate file for encrypted transmission
media Media files
addons Store local add on, which is generally used for add-on development
share Shared content with no specific purpose
What is add-on
Add-on is other software running in parallel with home assistant core
Add-on can be installed / started / configured through home assistant supervisor
Add-on is generally associated with home assistant
Add-on File editor
