1. What function do you want?
A. Light
How to Diagram:
- KC868-Hx relay controller output series connect with light.
- Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “light”.
- Switch terminal board connect with KC868-Hx relay controller by RS232 cable.
- Such as you can use any two line button, there have two line, when short , light will be ON, short again, light will be OFF, just repeat. If short K1 two line, turn ON/OFF light1, if short K2 two line, turn ON/OFF light2…. If use a 4 key switch panel, you need connect 4+1=5 line from wall swith panel with switch terminal board. If use a 6 key switch panel, you need connect 7+1=8 line from wall swith panel with switch terminal board. +1 line means “COM” line. So you can use CAT5 network cable for wall switch use, wall switch panel not need power supply.
B. Curtain or blind
How to Diagram:
- KC868-Hx relay controller output connect with curtain or blind motor. The motor should be work with AC220V. Every curtain motor need two relay output port used. Such as curtain1 use relay1 and relay2, curtain2 use relay3 and relay4…..
- Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “curtain”.
- You can define one button for curtain “UP”, another button for curtain “DOWN”
C. Garage
D. Air conditioner
E. TV, DVD,STB and other multimedia equipment
F. Power socket
G. Fountain water flow
H. Swimming pool
I. Water pump
J. high-power device (like water heater, air conditioner)
K. CCTV IPCameras
L. Security sensor
2. Which products to chose?
