KinCony DI8 is PCF8574 IO Expansion i2c relay board. extend 8 channel digital input port (with optocoupler isolation circuit). digital input support use by dry contact signal. 8 LEDs show INPUT state on PCB. A0,A1,A2 PCF8574 i2c address can set by DIP switch. DI8 support install on DIN RAIL.
it’s open source board. here is schematic for DI8
it support integrate to home assistant by ESPHome. here is yaml file for ESPHome.
here is arduino demo source code for PCF8574 digital input
Power supply: DC 9-24V
PCB size: 90mm*50mm
Digital input : 0V OR power voltage OR dry contact
A0,A1,A2 DIP switch set for PCF8574 i2c address.
LEDs on PCB for every digital input state.
all terminal is removable.
