This is ESPHome configure for KC868-A8 smart home automation board. example for use output1-8 and input1-8 by PCF8574 IIC chip.
platform: ESP32
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
# Optional manual IP
manual_ip:
static_ip: 192.168.1.199
gateway: 192.168.1.1
subnet: 255.255.255.0
– id: ‘pcf8574_hub_out_1’ # for output channel 1-8
– id: ‘pcf8574_hub_in_1’ # for input channel 9-16
# Individual outputs
– platform: gpio
pcf8574: pcf8574_hub_out_1
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
– platform: gpio
