Now , All Smart Controller (KC868-H2,KC868-H4,KC868-H8,KC868-H16,KC868-H32) have new firmware, and have new function
followings:
1:The function of power-off memory of relay switch is added. If the power is cut off suddenly or power failure, the relay will automatically return to the state before the power cut when the power is called again.
2:When press switch board , controller will auto send information to client software in TCP mode.
3:Add bootloader function, next time when need to update firmware can download to RS232 port, also can use
USB-RS232 adapter cable to flash program.
4.Add ALL relay ON command.
5.Add ALL relay OFF command.
6.Add reverse status control mode command. (Such as ON->OFF , OFF->ON,just opposite to the current state)
7.support new switch terminal board that can use 433MHz wireless remoter control MAX 32 channel relay.
