KC101 is 4 channels tuya universal WiFi wireless smart switch with RF 433MHz module, it’s a DIY kit for DIYer. it for your smart home system to remotely and automatically turn ON/OFF home appliances and electronic devices by mobile phone APP. It also can be controlled by 433MHz RF remoter. It can connect and control four appliances on APP at the same time, and you can independently turn ON/OFF each relay. It also supports timing turning ON/OFF the appliances at a specified time, and share to others so that you can control your smart home together with your family. You can also voice control your home appliances by Amazon Alexa and for Google Home/Nest,IFTTT and enjoy intelligent life and make your home smarter.
Features:
*App Support: Free iOS and for Android mobile App Smart Life / Tuya Smart.
*Sync Status: Real-time device status provided to App.
*Remote ON/OFF: remotely control relay from anywhere.
*RF Remote control: Turn ON/OFF by 433MHz RF Remote indoors,Only support 433MHz Learning code.
*3 Working Modes: Switch can config for interlock/self-locking/inching modes.
*Independent control: Control each relay separately in APP Tuya.
*Supports remotely turn ON/OFF connected appliances, for example light, electric kettle, electric rice cooker, electric curtain, etc.
*Timing: Supports 8 enabled countdown/single/repeat timing tasks to turn ON/OFF at specified time.
*DIN Rail Mounted: Great for industrial control.
*Voice Control: Compatible perfectly with Amazon Alexa, for Google Home, for Google Nest,IFTTT.
*Share Control: Control your smart home together with your family.
What can I use it for?
*Connect a light, remotely control the switch of the light.Connect a light, remotely control the switch of the light, and can also switch on and off regularly
18:00 On 22:00 Off
*Open your curtains regularly 6:30AM
*Change the water for the fish tank regularly
*Use mobile phone or voice control Garage door switch
*Control your heater remotely
*And your coffee machine
*Connect a water pump, remote control or timer switch
Specifications:
PCB size: 87mm*92.5mm
with plastic shell size: 115mm*90mm*40mm
Input voltage : DC 9-36V AC 7V-25V
Max current : 250V/10A.
WiFi standard : WiFi 2.4 ghz b/n/g.
The life of Relay Model is more than 1,000,00.
Default inching Function: Press the open relay by mobile phone, then cut off the pull-on imediately, you can set the inching time in APP , it has the timing-share function at the same time.
Self-locking when press the inching and locking button with the light on. Press open relay to pull-on, press close relay to cut off.
Note :
Your have the correct wif password.
Your smart phone or tablet must have access to APP store or google play.
Your router is MAC-open.
Your smart phone or tablet has connected to a 2.4g wifi with internet.
Default inching time 0.5s , you can set inching time from 1s to 3600s in APP ( smart life / tuya smart).
We have prepared all the electronic components for you, as long as the welding is correct, it can be successful.
This is what it looks like after welding.
This component list for KC101 smart controller.
here is schematic for KC101 Tuya smart controller.
use by Tuya mobile phone application directly.
lamp remote control by mobile phone.
lamp control by 433MHz remoter
lamp control by Amazon alexa or Google home speaker.
lamp control by wall switch panel (you can use any momentary button)
remote control pump
here is our YouTube video tour , step by step.
if you need any help, you can post your questions to our technical support forum:
https://www.kincony.com/forum/forumdisplay.php?fid=3
Bundle B = Bundle A + 433MHz remote
YouTube video tour: https://youtu.be/ajcTC4MIHvw
