KC868-A8S hotel room demo configure for ESPhome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8S (https://www.kincony.com/forum/forumdisplay.php?fid=24) +--- Thread: KC868-A8S hotel room demo configure for ESPhome (/showthread.php?tid=1946) Pages:
1
2
RE: KC868-A8S hotel room demo configure for ESPhome - admin - 03-08-2023 how many channel analog input ports you want? RE: KC868-A8S hotel room demo configure for ESPhome - Vokob - 05-11-2023 Hello What about sim800l? I'd like send sms. Show me demo plz RE: KC868-A8S hotel room demo configure for ESPhome - admin - 05-12-2023 see here have sample SIM800L SMS config yaml in ESPHome webpage: https://esphome.io/components/sim800l.html RE: KC868-A8S hotel room demo configure for ESPhome - Vokob - 05-12-2023 (05-12-2023, 12:28 AM)admin Wrote: see here have sample SIM800L SMS config yaml in ESPHome webpage: https://esphome.io/components/sim800l.html I can't do it. what data should I specify in rx and tx? RE: KC868-A8S hotel room demo configure for ESPhome - admin - 05-12-2023 because in China have stopped use 2G, unless i can test it for you. RE: KC868-A8S hotel room demo configure for ESPhome - Vokob - 05-12-2023 (05-12-2023, 10:53 AM)admin Wrote: because in China have stopped use 2G, unless i can test it for you. Can you see my yaml config? Is it correct?: esphome: name: b8gsm platform: ESP32 board: esp32dev ota: logger: api: ethernet: type: LAN8720 mdc_pin: GPIO23 mdio_pin: GPIO18 clk_mode: GPIO17_OUT phy_addr: 0 uart: baud_rate: 9600 tx_pin: GPIO15 rx_pin: GPIO13 sim800l: on_sms_received: - logger.log: format: "Received '%s' from %s" args: [ 'message.c_str()', 'sender.c_str()' ] sensor: - platform: sim800l rssi: name: "Sim800L RSSI" text_sensor: - platform: template id: sms_sender name: "Sms Sender" - platform: template id: sms_message name: "Sms Message" switch: - platform: template name: "sms water level error" turn_on_action: - sim800l.send_sms: recipient: '+79260090270' message: "water level error!" - platform: template name: "call water level error" turn_on_action: - sim800l.dial: recipient: '+79260090270' binary_sensor: - platform: sim800l registered: name: "Sim800L Registered" RE: KC868-A8S hotel room demo configure for ESPhome - admin - 05-12-2023 it need to test and debug, so i can't easy to say whether correct. |
