KC868-A128 configure for ESPhome - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A128 (https://www.kincony.com/forum/forumdisplay.php?fid=34) +--- Thread: KC868-A128 configure for ESPhome (/showthread.php?tid=2114) Pages:
1
2
RE: KC868-A128 configure for ESPhome - admin - 02-12-2023 thanks for your help. RE: KC868-A128 configure for ESPhome - soethu - 12-03-2023 I tried to update esp home server but I can't upload yaml file. I don't know why. ESP sever showing offline. I used 3 network cables. 2 are on KC868 server and 1 is connecting on A128. Please give me some advice. Thank you! Updating /config/esphome/kc868-server.yaml ------------------------------------------------------------ INFO ESPHome 2023.11.6 INFO Reading configuration /config/esphome/kc868-server.yaml... WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins WARNING GPIO5 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins WARNING GPIO15 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins WARNING GPIO15 is a strapping PIN and should only be used for I/O with care. Attaching external pullup/down resistors to strapping pins can cause unexpected failures. See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins INFO Generating C++ source... INFO Compiling app... Processing a128 (board: esp32dev; framework: arduino; platform: platformio/espressif32@5.4.0) -------------------------------------------------------------------------------- HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5 Dependency Graph |-- WiFi @ 2.0.0 |-- ESPmDNS @ 2.0.0 |-- Wire @ 2.0.0 RAM: [= ] 11.2% (used 36744 bytes from 327680 bytes) Flash: [=== ] 33.9% (used 622121 bytes from 1835008 bytes) ========================= [SUCCESS] Took 11.32 seconds ========================= INFO Successfully compiled program. ERROR Cannot upload Over the Air as the config does not include the ota: component ======== [ERROR] /config/esphome/kc868-server.yaml ======== ======================== [SUMMARY] ======================== - /config/esphome/kc868-server.yaml: FAILED RE: KC868-A128 configure for ESPhome - admin - 12-04-2023 can you take a video send to whatsapp number: +86-15381188302 RE: KC868-A128 configure for ESPhome - soethu - 12-04-2023 (12-04-2023, 02:25 AM)admin Wrote: can you take a video send to whatsapp number: +86-15381188302 I just sent the video via WhatsApp. Please kindly check it out and let me know asap. Thank you so much! Soe RE: KC868-A128 configure for ESPhome - admin - 12-04-2023 post your "kc868-server.yaml" file at here. RE: KC868-A128 configure for ESPhome - gabi_jackass@yahoo.com - 05-27-2025 Hello. I love the way it works with EspHome, but I don't see a configuration section for the analog inputs, RS485 and serial. Can you please help me with this ? RE: KC868-A128 configure for ESPhome - admin - 05-27-2025 this is analog input code for ESPHome: Code: sensor: |
