EZO sensor not working - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-E16S/E16P (https://www.kincony.com/forum/forumdisplay.php?fid=26) +--- Thread: EZO sensor not working (/showthread.php?tid=6064) Pages:
1
2
RE: EZO sensor not working - admin - 07-15-2024 you need to send command to sensor to enable i2c. sorry, i am not used it before. mabye you can contact with sensor's seller. RE: EZO sensor not working - TeRRia - 07-15-2024 OK let me try testing all of this on a separate ESP32 board. Will share results. RE: EZO sensor not working - admin - 07-16-2024 good luck. RE: EZO sensor not working - TeRRia - 07-18-2024 (07-16-2024, 11:36 AM)admin Wrote: good luck. Thanks Admin. So I made good progress! Anybody using Atlas Scientific probes: While it works with both UART and I2C, by default the probe is set on UART. To switch the board to I2C, follow these steps: Interfacing Atlas Scientific Ph Sensor with Arduino via UART/I2C (how2electronics.com) UART: led is green, with I2C activated, it's blue. Once done, you will see your probe in the logs. Admin: How do I connect 2 probes (I have a pH and ORP) ? First one is connected using the I2C extender and this works fine. Second one: I tried using the I2C connector on top of the E16P board but it doesn't work. RE: EZO sensor not working - admin - 07-18-2024 First one is connected using the I2C extender and this works fine. use by which board? which port? can you upload a photo? |
