KC868 server16 and GSM module - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KinCony AS (https://www.kincony.com/forum/forumdisplay.php?fid=64) +--- Thread: KC868 server16 and GSM module (/showthread.php?tid=8286) Pages:
1
2
RE: KC868 server16 and GSM module - admin - 08-30-2025 do you use by ESPHome? RE: KC868 server16 and GSM module - Rupesh - 12-15-2025 Isn't the GSM module on the Server16 connected directly to the Compute Module (CM4) via USB? I assume that means we should be using the native Home Assistant SMS integration or Shell Commands pointing to the serial port, rather than ESPHome. Beautifulideas.in @admin, could you clarify if we need to release the serial port from the OS first, or can we just point Home Assistant directly to /dev/ttyUSB? RE: KC868 server16 and GSM module - admin - 12-15-2025 Server16 4G sim7600 module rxd,txd pin use by CM4's gpio directly, there are GPIO12, GPIO13. here is CM4 pin define: https://www.kincony.com/forum/showthread.php?tid=5418 we already have node red demo for that. just send AT command by these two gpios. |
