KC868-A16 ethernet work with home assistant by ESPHome configure - Printable Version
+--- Thread: KC868-A16 ethernet work with home assistant by ESPHome configure (/showthread.php?tid=1628)
Pages: 1 2 3 4
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - admin - 01-20-2026
do you have set some IFTTT? maybe you can factory reset the board. there is a "factry reset" button in KCS webpage. click it then test again.
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - Konstantin - 01-21-2026
(01-20-2026, 09:03 PM)admin Wrote: do you have set some IFTTT? maybe you can factory reset the board. there is a "factry reset" button in KCS webpage. click it then test again.
no, I did not install it, I do not know what IFTTT is. I'm new to this, this is my first experience using HA and ESP Home. So if you can tell me in more detail what I should do. thanks
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - admin - 01-21-2026
you can download KCS v3 firmware to test a long time , whether work well. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - Konstantin - 01-22-2026
(01-21-2026, 11:20 PM)admin Wrote: you can download KCS v3 firmware to test a long time , whether work well. here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3-firmware-esp32-board.html
OK, I'll try.
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - Elgatoguiri - 02-22-2026
(01-11-2026, 12:53 PM)admin Wrote: updated yaml file for newest ESPHome.
  friendly_name: a16
esp32:
  board: esp32dev
  framework:
    type: arduino
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
pcf8574:
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      mode: INPUT
      inverted: false
  - platform: dht
    pin: 32
    temperature:
    humidity:
      name: "Living Room Humidity"
    update_interval: 60s
web_server:
  port: 80
yaml file download:
The framework uses type: arduino
Currently I have a board set up and in use over wifi. It uses type: esp_idf.
I want to change to ethernet. Do I have to change the type to arduino?
Thanks!
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - admin - 02-22-2026
ardunio or esp_idf all support use by ethernet. you can use any platform.
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - Elgatoguiri - 02-23-2026
(02-22-2026, 10:59 PM)admin Wrote: ardunio or esp_idf all support use by ethernet. you can use any platform.
That's awesome, thanks!
So, just to confirm. If delete the wifi section and add this to my current working .yaml then the ethernet should be working without any problems, right?
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - admin - 02-23-2026
yes, it's right.
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - Elgatoguiri - 03-18-2026
(02-23-2026, 10:48 PM)admin Wrote: yes, it's right.
So, I'm about to replace the wifi section of the KC868-A16 to this:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
But chatgpt is arguing that it isn't the correct configuration for the board. It says I should use this config:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO5
RE: KC868-A16 ethernet work with home assistant by ESPHome configure - admin - 03-18-2026
A16 ethernet config yaml should be:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk:
    pin: GPIO17
    mode: CLK_OUT
  phy_addr: 0
