A32 Pro ESPHome yaml include RS485 modbus temperature humidity sensor
#21
what sensor address, you should check with sensor's datasheet or ask with your sensor supplier.
Ok, found it!
It would be great to be able to buy your proposed sensors through AliExpress and without extreme shipping cost.
Thank you for the provided code example in YAML!
Can you just give me a hint on how to adress more than one sensor via YAML-Script?
Best Regards Christian
(02-09-2025, 05:08 PM)doubleq Wrote: Thank you for the provided code example in YAML!
what sensor model?
